Cleat and stansion screws on the 342 - help!!
Stodge
Member Posts: 2,738 ✭✭✭✭
I have a number of screws on the deck that have to be backed out and sealed. And I have heard that the nuts are floating. I'll be darned if I can figure out where inside the cabin I'll need to cut headliner to access the screws. Can some other poor soul who's done this shed a little light on my search?
2014 Rinker 260EC
I can strap on the GoPro when I'm fighting with it. Should make for a fun video.
Starboard side is my project in April. You can get to most of these except the bow one again. You have to cut the liner. You can feel the fasteners thru the vinyl if you locate the mounts from the outside to the inside carefully.
Next trick is repairing the vinyl...
There are just washers behind the nuts and they are totally slathered in caulk you have to scrape off. pita Backing plate would be nice but once you get into it it you can see why it was not done. I suppose you could get something behind 2/3 screws if you tried but it will protrude into the cabin.
Use butyl tape for resealing the mounts, not caulk.
2014 Rinker 260EC
Just hard to believe this wasn't thought through a little differently during the mfg process. Sucks big time.
Keep us updated
I'll be removing the coffee maker as we don't use it, and a 1-way removal (destroying the plastic brackets that hold it in) is easier than taking the entire galley apart. The space will become a cupboard.
You can feel where the nuts are if you measure to know where they mount and come through to the inside.
Adding a backing plate would be hard once you see how they are mounted and the area they come through.
