Running 5.0 Mercruiser MPI with Bravo 3 on earmuffs
I hear so many conflicting theories. Can one run 5.0 Mercruisers with Bravo 3 outdrives on earmuffs? Just to see if engines come up to temperature, checking water pump, no leaks etc before the boat is put back in the water after sitting all winter. Not to rev but to just idle.
Never had an issue.
if you have interest how the bravo 111 and 5.0 MPI water flow goes from the muffs to the rest of the engine , I can post pictures from the Mercruiser original shop manuals
Paul
Any other steps to complete before firing up once the water is running properly.
06 Rinker 270
nonetheless, will still keep an eye for leaks in engine.
06 Rinker 270
the downside of removing all the treated water and leaving the blue plugs out is that scale and rust can form on internals- to include the circulation pump... if you're in salt water and don't flush that thing VERY well, it stands a good chance of bonding to the housing and breaking free in the spring when you attempt to start it up.
06 Rinker 270
i use the antifreeze (pink), and then I still lose the plugs over the winter... i'm not real worried about freezing, though, because where I'm at.
06 Rinker 270
06 Rinker 270
