big orange filter for 342 rinker placement
SERENDIPITY
Member Posts: 83 ✭✭
Has anyone install a BIG ORANGE filter in a 342 RINKER or similar boat .i see the hose going to outside the vent ,the other end disappeers along the wall .i cannot see my holding tank. its a 2006 tks for your input.
The vent line fitting coming off the tank was smaller than the tube size needed for the Big Orange AND the thru hull fitting. Some brainchild at the factory just tried to squish the tube on with the worm clamp. You may/may not have this issue. I put in the correct tube dia off the tank fitting, then used a barbed adapter to change over to the correct tube size. I did use the white head tubing meant for sanitation.
That tube at the bottom is just a stand off to keep it vertical due to how I mounted it.
110% solved my odor issues.
Either way I’m going to add a big orange filter under neath the portside seating, after seeing what you and Black_Diamond did, I’m just wondering if it’s worth the effort trying to find an existing one.
