Cabin Door
I cleaned out the tracks real well on the cabin sliding door.....should there also be some grease involved to keep it moving smoothly??
Best Answers
MarkB Member Posts: 3,991 ✭✭✭✭✭
I use small amounts of lithium grease.Boat Name: King Kong
Dream_Inn Member, Moderator Posts: 7,728 mod
I use a silicon spray, a bit less messy.Dream 'Inn III -- 2008 400 Express
I agree the silicon spray is a bit less messy, but the lithium grease lasts a lot longer (especially if the track gets wet).Boat Name: King Kong
TikiHut2 Member Posts: 1,431 ✭✭✭✭✭
I found the track completely unsupported back inside the far end of the track behind the helm. It made the door sag on the track when fully open so I glued a wedge loaded with caulking under the far end to support it.
Grease and lube that might clog with grit was completely unneeded once the track was properly supported. Check it out.2004 FV270, 300hp 5.7 350mag MPI Merc 305hrs, 2:20 Bravo3 OD w.22p props, 12v Lenco tabs, Kohler 5kw genset, A/C, etc.etc...Regular weekender, Trailer stored indoors, M/V TikiHut, Sarasota, Fl
