captiva 226 slow to plane
Recently bought a captiva 226 and have not used it much but with only 2 in the boat it seems slow to plane. It has a 5.0 volvo with a 21 pitch prop. I thought about going with a different prop since most of the time will be towing but would still like occasional top end speed. Would I be better to stay with my prop and add trim tabs? I'd appreciate feedback.
Best Answer
mvn Member, Moderator Posts: 756 mod
Here's some output from an optimal prop calculator I created in Excel. This example is for my boat. The blue line is theoretical boat speed versus pitch and the magenta line is RPM versus pitch. My WOT range is 4600 to 5000 RPM. For input, you just need a drive ratio and a prop efficiency number.
You can see from the output that I can run an 18", 19" or 20" 4-blade prop while keeping the WOT RPM within the allowable range. In my case I sacrificed top end speed for low end acceleration because I tow more than I cruise. For cruising, I would go with a 20" 3-blade on my setup.
MarkGood, fast, cheap.... pick two.
2019 MTX20 Extreme
My 226 on the other hand has a Merc setup. My optimal setup is an 18" 4-blade stainless with Smart-tabs. Lots of grunt for towing yet still has a respectable top end.
Mark
2019 MTX20 Extreme
It's so close that smart tabs would be a huge help, or, even venting the existing prop to allow it a head start before water tension closes the vents for basically the same purpose.... trim tabs are a fix, vents are a bandaid and only useful for someone wanting to retain the top end while adding some hole shot, and on a prop that's only a little bit too steep.
Am I crazy here?
I'll get you the model number of the tabs and a few photos as well.
Mark
2019 MTX20 Extreme
Mark
2019 MTX20 Extreme
Dave
Here's my Smart-tab setup. Some will say that they are mounted too close to the drive but they work just fine....no issues whatsoever and the performance improvement is VERY noticeable.
Mark
2019 MTX20 Extreme
See photo above. The black thing is a gas strut.
Mark
2019 MTX20 Extreme
Water tension based on speed/drag are going to flatten those things parallel to the hull as soon as they overcome the strut pressure... It'll hold them there until speed lowers and the strut can overpower the same water tension. In a hard bank, while at same time dropping speed, it may play a role, bit not a huge one. Unweighting the boat by banking that hard and lessening the tension may allow them to drop some, but I bet its hardly any... The stern is planted firmly, now like the bow. On a bass boat or overpowered boat, where the water cuts right at the transom, I'd figure them a bad idea. I've not met a rinker that runs that hard yet.
I would go traditional tab vs smart tabs.
With Smart Tabs you have no on the fly control. Your stuck with where there set.
I bought a set of Lenco tabs and they are phenomenal. I can change there position at any time for load balancing, get out of the hole or even low speed cruising from switches in the cockpit.
The best investment by far for my boat which is a 2004 Captiva 232.
Boat: 2004 232 Capitva CC
Boat Name: Mixed Nutz
Mark
2019 MTX20 Extreme
