Help with fuel consumption
buggyjdavbuggyjdav Member Posts: 134 ✭✭
Good Morning. We take delivery of our 342 next weekend and are taking it 150 miles or so to our marina via the Atlantic ocean. We have a 245 gallon tank I believe and have the twin Merc 5.7's. I am wondering how much fuel we will burn on this voyage running at maybe 60 or 70% power? I thought I read the boat does about 1.3 miles per gallon, this would be 195 gallons I believe, does this sound correct? Thank you
    My 2003 342 burns about 32gph at cruise. 350MAG MPI Bravo III 22P props.
    You should have 235 gal total between both tanks. You should try to have a 30% buffer to allow for running conditions, etc. running out of gas is something to avoid.
    New 342 or previously owned?
    You're not gonna want to run a constant engine speed on that thing if it's new.  You'll wanna constantly fluctuate and never hit WOT.  you can do this and stay on plane, and we're only talking about a 400rpm range or so.
    When you run a constant speed and load on a new engine, the rings won't float like you'll want, and instead lock in one position (like they ultimately will anyway) which will cause you compression issues later down the road... Push rods and guides will sluff and groove specific to that range, and possibly slice a third-party causing oil leak downs into the cylinder and creating a host of later issues.
    If it's already broken in, let er rip, man.
  • raybo3raybo3 Administrator Posts: 5,614 admin
    I am thinking my 342 burns 34 gph at about 3700/3800 rpm. That is about the "sweet" spot on my boat. Good luck with the trip and keep us posted.
    Really Handy do we have to get into this again........LOL
    rowboat, I doubt it's brand new......they haven't made the 342 since 2007 I think.
    buggy.....good luck with the new boat, you'll love the 342, it's a great boat.
    I have been playing with the vessel view I had installed over the winter. It claims that at 3600 RPM I'm burning about 25 GPH and we were going about 28 MPH.  So slightly better than 1 MPG.  I'm actually pretty happy with those numbers, assuming the vessel view isn't lying to me.  :)
    Stodge, you are probably correct with that.  Most 342 owners I know average around 1MPG going around 30-32mph.  I know my VV is very accurate (unfortunately).
  • MarkBMarkB Member Posts: 4,007 ✭✭✭✭✭
    I have a 260EC, with a single 350 MAG. Best mileage is at around 4000 rpm - burn 15 g/h at 30 - 32 mph.  So about 2 mpg.
  • buggyjdavbuggyjdav Member Posts: 134 ✭✭
    Thank you all for the help. We pick her up tomorrow.
  • EaglesNestEaglesNest Member Posts: 30 ✭✭
    buggyjdav,  how did your trip go?  what did you average?
