Help with fuel consumption
Good Morning. We take delivery of our 342 next weekend and are taking it 150 miles or so to our marina via the Atlantic ocean. We have a 245 gallon tank I believe and have the twin Merc 5.7's. I am wondering how much fuel we will burn on this voyage running at maybe 60 or 70% power? I thought I read the boat does about 1.3 miles per gallon, this would be 195 gallons I believe, does this sound correct? Thank you
You should have 235 gal total between both tanks. You should try to have a 30% buffer to allow for running conditions, etc. running out of gas is something to avoid.
You're not gonna want to run a constant engine speed on that thing if it's new. You'll wanna constantly fluctuate and never hit WOT. you can do this and stay on plane, and we're only talking about a 400rpm range or so.
When you run a constant speed and load on a new engine, the rings won't float like you'll want, and instead lock in one position (like they ultimately will anyway) which will cause you compression issues later down the road... Push rods and guides will sluff and groove specific to that range, and possibly slice a third-party causing oil leak downs into the cylinder and creating a host of later issues.
If it's already broken in, let er rip, man.
rowboat, I doubt it's brand new......they haven't made the 342 since 2007 I think.
buggy.....good luck with the new boat, you'll love the 342, it's a great boat.
