water in the bilge
rasbury
Member Posts: 8,270 ✭✭✭✭✭
We were out this weekend at a local marina and when we pulled the boat and I pulled the drain plug, I was shocked at how much water was in the boat. Usually if we are out for the day and I pull the drain, there is nothing.....We were out for two days and had no rain but I did use a hose to hose off the bugs we get but I can't imagine all that would get into the bilge . I am using the A/C at the dock, can it possibly make that much condensation? Also from the fridge? Having had to re build the starter because it got wet, I'm real sensitive to water down below. As far as pumps, I should have one in by the shower sump pump which I have seen, and when I hit the switch on the helm I hear the pump running in the engine compartment but I sure need to check and make sure the float switch is working....if that much water got in the boat from hosing it off, if left sitting at a marina with the rain, I'd think the dang thing would sink! Unless something has happened with my bellows or suddenly have an issue with a thru hull....I would think these would be a gradual issue and not what I'm experiencing....
Then I noticed one time that there was a drop of water next to the toilet seat. It was a clue.
When i opened the plastic cover on the macerator pump, there was more water. It was dripping from the tiny hole between the electric motor and he pump. Most of the water was sucked under the toilet seat because capillary effect. I decided to unmount the toilet seat and voilá! See the picture..
The o-ring seal of the axle that comes from the motor to the pump was leaking. Leaking water went under the toilet seat and couldn't be seen. The seat had not any kind of sealant under it or in the bolt holes, so the water (and some waste also) leaked under the toilet compartment and from there to middle bilge.
I changed the rubber o-ring an sealed the toilet seat with silicone, so if there will be any new leakage in the future, water wont go under the seat and to the bilge.
(there's a good tutorial videos on the Jabsco's website)
The leakage wasn't big, but even a small leakage gathers a good amount of water when it's on for a long time...
Leakage under the seat:
Laekage came from the hole between the black motor and the with pump set. Here's everything resealed:
The seal that leaked:
