Generator wont start
buggyjdav
Member Posts: 134 ✭✭
Had it running yesterday now it won't start. Checked breaker and fuses, cranks but won't start. Any ideas?
Haven't started the diagnostic process yet. Pretty sure mine is carb. IT's a 2002 Kohler 5E. At the beginning of the season I started it. It ran for 5-10 min then stalled. Has not started since. Guessing fuel or a wonky sensor.
#1 the fuel pump is electric- check the connection, mine was bad from the start.
#2 Check the impeller and make sure the seacock is open and the strainer not plugged. They over heat and shut down fast with these problems
#3 pull the anti-diesel valve and clean it. See the manuals in the generator section about this.
#4 try running a fuel line direct into a small gas can and run it from there if it starts. You can go super generous with either a can of gumout or similar.
#5 there is a fuel filter at the input to the fuel pump too. Check that. I removed mine and just stayed with the in-line version.
Good luck.
I forgot item #1 with the 5e: replace the spark plugs. there are (2) NGK-BPR4ES I think is the number. Double check. Even if they look good, replace them. These things eat them.
I have had this carb apart every year for cleaning, and was completely surprised by this. I have been working on motors my whole life and never seen a carb crumble like that.
I bought a replacement which is a newer model carb that Kholer switched to, the switch was to solve some of the reoccurring issues that have had with them.
I was able to get the whole carb assembly, new gaskets, and the inline fuel filter with overnight shipping cheaper than I could order just the carb for locally.
I actually leave the two screws holding the side in, and remove the top and side as one piece. It makes it much easier to put back in place.
The panels have pins that set into the base pan, sometimes getting everything lined and put back together is pain.
Once you take it off a few times, you figure out how to do it pretty easily.
Thanks!
So tomorrow I'll buy a new choke...
Surging is from running too lean, there is a fuel filter at the fuel pump inlet, it is a pita to get at, I replaed it with a 1/4" NPT barbed fitting, just use the in-line one. Also check the anti-diesel valve..screws into the carb from the side and has a wire attached to it, pull it and clean it..they are a common problem to go bad too.
You can remove the jets and clean them, also remove the anti-siphon solenoid and clean it for the cost of a can of carb cleaner.
Here is the one I bought for mine.
