Generator - Wont turn OFF
jhortajhorta Member Posts: 90 ✭✭
Anyone experience the generator NOT turning off??
    LaReaLaRea Member, Moderator Posts: 7,572 mod
    You mean you push the remote off switch and it still runs, so you have to go in the engine room to turn it off?  Or are you saying that you turn it off and the engine continues "dieseling"?
    Dieseling for a few seconds is a concern because it probably means you're overheated.  Dieseling that lasts 20 minutes will destroy the engine, and I state that from direct experience.
    Watch how you disrespect that Diesel word LaRea  ;)
    Yeah, I had to go into the Engine room and kill it.  Hitting the switch did nothing.  Started right up.  Im not  diesel though...
    Yeah, I think the same thing.  Will switch that first and see what happens.
    rasburyrasbury Member Posts: 8,263 ✭✭✭✭✭
    it's usually the other way around, would rather deal with this problem!
    Easy test with an ohm meter first.
    Haha....seriously.  It started up for the first time this season without a hitch.  Never seen it NOT wanna stop before.
    CrewLoungeCrewLounge Member Posts: 92 ✭✭
    Check the cannon plug on the black control box on top of the genie. May be a bad connection
    If you can't figure this out, you do realize that thing is worth a fortune, right?  I know plenty of people who would kill for that particular genny problem.
    Yeah, I figured your genny is gas ... dieseling happens on gas engines. Cut power and the engine keeps running.  212rowboat could probably explain the details better than I could. But I agree this sounds like a switch problem, not dieseling.
    any ol' rocker switch replacement, or should I be looking for a certain replacement?
    ok, I know this may sound very silly, but...when you hit the rocker switch on, you push the top of the switch.  Now, again, when you turn it off, you should be hitting the top of the rocker switch.  (not the bottom)  I know you are new to boating, but hey, it is the beginning of the season and let's just say I've done it before.  Cause if that switch is turning it on, it should be turning it off as well.
    I'll second the connection plug at the AC inverter on top of the genny. Mine corroded and the red wire pulled away from the plug. This yielded the opposite of what you have. The rocker switch in the cabin would not start it but would shut it down. Check the black or yellow wires on that inverter plug.
    edited June 2015
    I wanted to correct this statement. I finally got to fixing my starting issue. My genny starts fine at the generator but would not start at the switch in the cabin. On inspection I found the red wire pulled out of the plug on the side of the controller. I assumed this was my issue. Well after fixing the pulled wire today it did not fix my remote start issue. It will shut down at the remote switch but won't fire.  After some research it turns out that plug goes into the voltage regulator. With that disconnected red wire does that mean the genny was not charging my battery? So what do you all think, a bad switch in the cabin?
    FYI the remote start plug is actually on the back of the controller.
    YYZRCYYZRC Member Posts: 4,931 ✭✭✭✭✭
    edited July 2020
    @jhorta did you solve this?? Seems like you haven’t been around in a while...
