acc switch
ClintonClinton Member Posts: 44 ✭✭
2000 rinker 242 fiesta vee. What does the acc switch beside the cabin light switch do?
    Probably nothing. It might be prewired for a washdown pump or a swim light. There might be a wiring diagram on here for the 242. If not, email Cindy Scott at Rinker and see if she will send it to you. They are very helpful to have.
    Greg is correct nothing unless an option was added
    ACC normally means it is meant for an option that your boat doesn't have. A lot of the time, Rinker just installs the wiring, so adding that feature isn't a big deal. I have re-used one of the my accessory switches and cable to power something else. Made it really easy.  Just have to use a multi meter to figure out what cable is attached to that switch.
    If it doesn't power anything would the light for the switch still come on?
    mvnmvn Member, Moderator Posts: 744 mod
    Yes.  The indicator light is connected to the output of the switch contacts regardless of any other connections.
    Mark
    2019 MTX20 Extreme
