Rinker Quality In Question
So in the process of working through all of the issues with my "new to me" 2005 262 Capteva, I removed the gauge panels from the dash and was amazed at how rough the cuts were in the base material. Under the pretty wood grained covers is a very rough and jagged mess that looks like someone cut it out with a hammer and chisel. Last week while my boat was in the shop getting the engine and outdrive removed to fix a leaking transom assembly, the shop owner sent me a picture showing how rough and jagged the transom penatration is. He said it's the worst cutout he's ever seen. It's so bad that the transom assembly seal will barely cover the jagged cut penetration and they had to go in with some gel coat material and build it up to ensure enough surface area to get good compression of the gasket.
What's up with Rinkers craftsmanship? Do they not have templates and proper cutting tools to make a smooth and accurate cutout for dashboards and transom penetrations?
Sorry but I couldn't get the picture to link from Photobucket for some reason.
Post edited by Ezgoin on
I guess anything is possible, but there's no indication as to why he would have. No added gages or anything else. If I can get a pic to post I'll try and post one.
Dave
HAHAHAHAHAHAHAHAHAHAHAHAHAHA!!!!!!!
But here's what I'm wondering about @Ezgoin ... Does that transom cut fall within Rinker's established manufacturing tolerances? If yes, then it's just an ugly piece of work. If not, then it's a defect that Rinker should have addressed at the factory.
The boat is ten years old, so I wouldn't have much hope of that, but it's a nice thought.
