Rinda Diacom Diagnostics - bogs at 3000rpm, wont plane
Boat is a 2000 rinker 242 with a mercuriser mag MPI 350. Been fighting this issue all summer. Idles fine and puts around fine, but when i go to give it power and plane out it goes to about 2800-3000 rpm(by my tach) and stays. It just bogs real bad and will not plane out. I have replaced fuel pump, pressure regulator, dist. cap, rotor, coil, IAC valve. I cant figure it out. Below is a screen shot of the live Diacom that maybe someone can spot an issue. Boats not throwing any trouble codes. My only ides left are either oil pressure sensor being bad as ive read else where, havent had the chance to check it since learning on it, or a PCV issue. According to my manual on this boat the PCV valve is on the port side of the engine. Mine is on the starboard and runs to the connector on the back of the throttle body by the IAC valve. The port side is just an open elbow that goes to the flame arrestor. i tried switching the two but the hoses are different sizes so i dont think they are wrong based on that but maybe someone else will know better.
Thanks for the help in advance!
I do use the tabs to help come on plane sometimes when a heavy load but havent needed to usually. I have been testing with just myself and wife and a light load other than the 3/4 fuel tank so they shouldnt be needed as it usually will pop right out of the water. It is a bravo 3 drive thou and i have checked and do not think the props are slipping.
I want to say its 26 pitch props also but not guaranteeing that.
Also want to say thanks for the help and taking the time to answer guys i really appreciate it!
check your fuel pressure on yours as in my vast amounts of research thats one things i kept running into. See if its proper and also check your fuel pressure regulator at the same time and see if when you unplug the vacuum hose that runs from the manifold to the pressure regulator if your fuel pressure rises. Apparently the pressure regulator is notorious for going bad and causing this issue. Also when you do a fuel pressure test, let me know your results. My pressure kicks to 30 when i turn the key on then runs at 25psi and when i hit WOD it will go to about 32. Specs for my manual state 30psi at 1800RPM.
From what i have been reading on my issue, its usually a fuel pressure issue but i think i may have drawn a short straw and run into something more complex or possibly more simple that im looking over but i recommend checking the fuel pressure just to get a starting point to eliminate an entire issue. Someone else here who knows more may chime in and have another idea but thats where i started at.
The pulse width is decided by the ecm depending on the rpm, map, and tps. If your fuel supply is low or has water in it it will not allow the rpm you need and may max out. This will not set a code or an audible alarm.
Check you fuel pressure with the just the key on, check at the start and then watch it for 5 mins without starting. Then start it and observe at idle, and over a few minutes. Then check it under load.
If the pressure does not seem to be an issue, I would then run the motor from a portable tank of fresh gas from a gas station not on the water. See if the performance improves.
There are two different fuel pressure ratings on this motor, and I'm not sure what yours should be. The mark will tell you if what pressure the regulator is designed to regulate at.
Pink is the 30psi regulator and the blue is 43psi.
I have siphoned all the gas out of the tank and am going to replace it with fresh gas and hope maybe the gas has just been bad this whole time.
