head
rasbury
Member Posts: 8,759 ✭✭✭✭✭
I am on the water, tropical cyclone right where I am at, yuk. Having issue with the head- when you pump the toilet to the tank it works fine but then slowly the head fills back up almost like a cyphen- I tried with the switch both ways, same result. Also gurgles like there is pressure - I put in a rebuild kit last year. What is up with this toilet? Does not overflow...
That's the big rubber valve right there where the hose to the tank connects to the pump? If that's right and I pull that hose off, stuff will run out all over? I am in a marina and don't want an event, although with the waves in this marina, no one would notice. We don't use the head that much, surprised it failed this soon.
