head
rasburyrasbury Member Posts: 8,659 ✭✭✭✭✭
I am on the water, tropical cyclone right where I am at, yuk. Having issue with the head- when you pump the toilet to the tank it works fine but then slowly the head fills back up almost like a cyphen- I tried with the switch both ways, same result. Also gurgles like there is pressure - I put in a rebuild kit last year. What is up with this toilet? Does not overflow...
