Shore power not working
dropout
Member Posts: 138 ✭✭✭
2005 Rinker 300
I searched the past posts but couldn't find an answer.
Shore power works on my port side but nothing on my starboard side, not even the green light on the panel.
Is there another breaker besides the one under the helm?
Any ideas?
Any ideas?
It sounds like, given your light is off, that the isolation switch is off. Find this, switch it on, and you should see the light come on. It's best that you switch off the port isolation to be safe, before you switch on the starboard isolation.
Guess I could see what my port side indicates but I never dock on that side.
Steady Green = normal
Flashing Green = breaker opened due to overcurrent or was turned off manually
Red = breaker opened due to leakage fault
Amber = reverse polarity
