knocking and clanking sound
mheitman23
Member Posts: 25 ✭✭
I have a 2001 captiva 232 with the 5.7 mercruiser efi...when I went out today it started fine and idled through the no wake and when I went to take off when it got to about 2k rpm it started knocking/rattling sound in the motor and the more rpm the more it did it..i stopped and took off and it kept getting more loud. I heard this same noise about a month ago while I was cruising but it stopped almost right away but this time it kept getting more loud. It only does this sound when its under load also any help would be helpfull
im thinking it is gimbal bearing or u joint.. oil is all fine
Where in MN are you?
