Balancing the boat in the slip - 2006 Rinker 390
JPCRUZE
Member Posts: 41 ✭✭
When my boat sits in the slip it leans to port side. I searched the other threads about balancing but have not found any ideas on how to fix it. There is not much on the boat I think it is a design issue where the port side from bow to stern has the galley below deck and the fridge and ice maker above deck and then a full battery bank of 6 batteries. The previous owner said when he bought the boat he addressed it with Rinker and it is just heavy equipment on one side. The previous owner said the best way he addressed it was to keep more fuel on the starboard. Any other suggestions for balance? Anyone put bags of sand on the boat or anything like that?
Thanks for any suggestions
JP
JP
Is your boat different from other 390s?
In rough seas, I wouldn't want to rely on fuel to balance the boat. Suppose your port tank gets contaminated, so you have to run both engines off the stbd tank. Then you're really unbalanced, and suddenly you get caught in an unexpected storm ... it's unlikely, but not impossible.
It's going to cost, and it's going to be a pain, but you could consider moving the batteries to the other side to balance the boat.
I wouldn't put more weight on the boat, especially the stern, as this will severely impact performance - you will struggle to achieve plane in a decent time frame.
