The new dash
Stodge
Member Posts: 2,738 ✭✭✭✭
I don't think I ever posted the finished product in use.
06 Rinker 270
06 Rinker 270
I kept the multi gauges because I don't have smartcraft fuel senders, so that's my only view of the fuel tanks. Not sure if I'll try to add the smartcraft fuel senders since getting to the tanks is next to impossible.
Come to think about it, my FFG is mounted in that little panel just to the left of the left most cup holder.
06 Rinker 270
I have the SmartCraft Tach System Guage. It has an LCD screen and provides system diagnostics, as well as system parameters like oil pressure, water pressure, rpm, gas tank level, gas usage. It isn't as good of a display as Vessel View but it does provide pretty much everything I need.
Here's a picture. It replaces your engine tach guage.
& yes, I bought my VV for 3 things: fuel flow, accuracy, and monitor alarms. It is fantastic for all of them. For instance, two weeks ago I had an alarm and it said it was for gear lube. I would've never known what it was, in the middle of a trip home because my gear lube level was fine. But, the sensor in the reservoir had gotten stuck and made the alarm. I took a toothbrush (hey it's what I had at the time, and no it didn't go back where I got it) and was able to fix it in seconds.
06 Rinker 270
