Gearlube in driveshaft bellow
swedeswede Member Posts: 88 ✭✭
Gear lube level dropping after we used the boat filled it up same thing next time.
Pulled of my bravo 3 and i hade gear lube in the driveshaft bellow.
Did a pressure test 10psi after 20 hours it hade dropped to 9psi.
Ihave turned the shaft many times.
Dropped 1psi in 20h.can it be problem ?
