Gearlube in driveshaft bellow
Gear lube level dropping after we used the boat filled it up same thing next time.
Pulled of my bravo 3 and i hade gear lube in the driveshaft bellow.
Did a pressure test 10psi after 20 hours it hade dropped to 9psi.
Ihave turned the shaft many times.
Dropped 1psi in 20h.can it be problem ?
ok
Special tool needed i guess.
Not something I'd tackle - I know my limitations!
Using loctite to the oil seal to oil seal holder ?
