Head winterize
kingsqueenkingsqueen Member Posts: 10 ✭
I am going to winterize the head on my 342 this week. I have a Jabsco self priming pump. Should I disconnect hose and pump anti freeze thru system or just pour anti freeze into toilet and flush?
Does anyone have video on how this is done? This is my first time winterizing.
Thanks for your help.
    As far as I know my mechanic pours "red pop" down the bowl and flushes.  Same for the shower, they pour it in until the stuff comes out the side.
    I hire out all the winterize tasks because I know I don't know what I'm doing.  If this is your first time you may want to get someone local to walk you through it.  You have the A/C, Ice Maker, fresh water, genny, engines, etc. to winterize.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,954 mod
    You will need to close your seacock and disconnect hose from there and pump pink thru.  This will winterize the line that feeds water into the head as well.  Once you draw pink into toilet, fill it twice and flush.  This should allow pink thru the rest of the system to your waste tank.  Hopefully you pumped out your waste tank first.
    At my marina they drain the fresh water tank and pour a couple of gallons of pink "non toxic" anti freeze into it. Then all taps, the toilet, the fresh water wash down, the shower in the head, the transon shower are all run until they spit red. This circulates the "red pop" through both holding tanks, the hot water tank, all pumps and sumps, all taps and sinks and the ice maker lines. In the spring the fresh water tank is filled and dumped, then filled half full and I add a cup of bleach, fill it full and dump it again then I fill it up for use. The hot water tank is filled with fresh water and dumped too.
    Man I am glad I dont have to winterize any more.
    Rub it in Steve, you have to be lovin' your new location! :-)
    Steve, isn't your boat still up north and shrink wrapped?
    My boat is on the way MT.
    Here is the view from my kitchen. The dock will be built by the big tree.
    Very nice Steve!  Enjoy!  Love those large lanais!
    Thanks John
    Nice picture Handy. Where again?
    Cape Coral
    Nice handy looks like a great set up I'm envious
    Good for you Steve, looks beautiful. How could anyone get tired of that scene?!
  • raybo3raybo3 Administrator Posts: 5,617 admin
    Looks great Steve. Enjoy........
    Ray said something nice!!!!! :D
    I always say nice things its just that you misinterpret what I say......LOL
    Kingsqueen, should not need to remove the hose but Just add some pink to the bowl and flush a few times (if you have the manual pump that draws from the lake), once you're out of the water. Some like to add pink down to the seacock and close it for the winter.  Others like to leave it open and dry.
    Also jealous of Handy's setup.  I was just winterizing today, yuk!
  • aero3113aero3113 Member Posts: 9,964 ✭✭✭✭✭
    Don't forget to pour some pink in the shower sump.
