2003 - 250 FV Merc 5.0 MPI not cranking
rinkerboy
Member Posts: 46 ✭✭
Hi Guys,
The MPI engine will not crank but can hear the solenoid operating, no matter whether its on battery 1 or 2, even on emergency start.
I have put the batteries on charge via Shore power for the night. Tomorrow I will clean the battery connections and check for power drop through to the starter via the solenoid.
Anyone know what tools I need to remove the starter unit from the engine and then strip it down, are there any special tools needed.
Thanks
Thanks
2003 - 250 FV MerCruiser 5.0 MPI
Is the transmission in neutral?
Been told there is a circuit breaker on the engine, so will check that tomorrow too.
Checking the circuit on Sunday with a meter, found although the slave solenoid alongside the circuit breaker was clicking. It was not bridging, so I bridged it with a spanner and presto it started.
Getting an OEM item here in UK, but noticed it looks if the solenoid could be dismantled for repairs as a spare.
Am I right.
Thanks guys
