Stainless seacocks?
BellevilleMXZ
Member Posts: 732 ✭✭✭
Both my head and A/C shutoffs are seized in the open position, so need to be replaced. The ones on there are brass/steel, and are quite crusty looking. Is there a better replacement available, maybe brass/stainless?
You might see stainless valves, but they will specify that they shouldn't be used below the waterline.
Great thanks. Yeah they look to be bronze.
IMO, either the salt water rated bronze as LaRea has suggested or Marelon. Marelon is getting a lot of good press for it's strength and resistance to any form of corrosion including galvanic corrosion. Quality 1 1/4" bronze runs anywhere from $75 to over $100. Marelon are quite a bit less. I'd do a bit of research first. You aren't in salt water so bronze corroding would not really be an issue and it may be stronger than the Marelon.
Andy
The handles are all rotten, as they are just plain steel. Yes bonded.... I would assume dampness in bilge caused the rot???......no other issues anywhere, clean boat. They might move, but wasn't going to try while in water...lol
To this end, I have had good luck unseizing valves through repeatedly applying stress in the close and then open directions, each time going a little further in the close direction.
