Battery Jumper
06Rinker270
Member Posts: 1,277 ✭✭✭
Hi guys, one of my additions to my on board toolset is a battery jump start. Will this be sufficient if my battery were to die? I believe it is but not too familiar with these.
http://www.westmarine.com/buy/rdk-products---compact-lithium-jumpstarter--16788853
thank you,
Patrick
thank you,
Patrick
Patrick
06 Rinker 270
06 Rinker 270
I bought this yesterday to carry along for $80. Hope it works ok. The one 270 bought looks more compact and lighter, which would be nicer for the boat.
http://www.batterychargers.com/ip-1850fl/
BTW, I also have a Ryobi inflator/deflator that uses those same batteries. Fantastic tool - much faster than any 12V plug-in inflator.
http://www.westmarine.com/buy/west-marine--1200-amp-powerstation-pro--15808520
06 Rinker 270
http://www.amazon.com/Black-Friday-Sale-Brightech-Electronics/dp/B00K0VMXDQ/ref=sr_1_1?ie=UTF8&qid=1448826566&sr=8-1&keywords=scorpion+battery
Andy
https://www.google.ca/search?q=west+marine+battery+jumper&client=ms-android-bell-ca&prmd=isvn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwigqN_WprfJAhXIqh4KHQf0C48Q_AUIBygB#imgrc=pr5vT_CB6p3S7M:
https://www.google.ca/search?q=west+marine+battery+jumper&client=ms-android-bell-ca&prmd=isvn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwigqN_WprfJAhXIqh4KHQf0C48Q_AUIBygB#imgrc=X0p1zBEwPGoG3M:
@Markb got me change my mind about wanting one with a compressor. I'm done with this hand pump mess.
06 Rinker 270
http://m.target.com/p/coleman-high-performance-rechargeable-pump/-/A-11115252?disable_sitespect=true
http://youtu.be/WtsGATbSvJA
Andy
doesnt look like much
06 Rinker 270
06 Rinker 270
@06Rinker270. Is it worth having a 500 watt inverter? Short answer - it depends.
We have discussed this topic at length in the past and the discussion may be archived.
In short: 500 watts will run modest loads such as lights, fans, tablets and maybe a stereo for a while. The "for a while" depends entirely on the condition, type, number and rating of your battery(ies):
More specifically: To know what your boat's battery system can handle you need to know the Ampere Hour rating of your battery(ies). That is a rating of how long it can handle a specific ampere load for X amount of time. For example 5 amps for 20 hours would be a 100 Amp Hour (AH) rated battery. This should be printed on your battery or easy to find out.
A more accurate load calculation might be: the Reserve Minute Capacity rating of your battery(ies) which is the number of minutes a battery can maintain at least a minimum safe voltage under a 25 amp load. This should be printed on your battery or easy to find out.
For example, I have 5 series 31 AGM batteries. each one is rated at105 AH and 200 Reserve Minutes. Because they are wired together properly that total would be almost double. I do not have an inverter as they will run any 12v load that I have on the boat for 24 hours and even combinations of 12 volt loads. An inverter would make them even more powerful (for a shorter period of time). Because of the number (5) and rating of my batteries I would probably go with a 1500 watt inverter.
Next you want to be able to calculate potential loads on your battery(ies). I usually convert loads to ampere hours (amps) as I find that the most useful yardstick.
IF I remember correctly, at any fixed voltage (say 100v or 12v) amps= watts/volts.
So using your 500 watts to see how many amps that will draw I think you go amps= watts/volts, therefore amps (at 12v) amps = 500/12 is 4.5 amps or amps (at 100v)amps=500/110, therefore amps = .5 amps.
I hope this was somewhat helpful? :-)
You will find two classes of inverter "pure sine wave" and "modified sine wave". Pure sine wave inverters create voltage signals that are very close to an ideal sine wave. Modified sine wave inverters create voltages signals that look like a combination of square waves (a stepped wave). Pure sine wave inverters are much more expensive than modified sine wave inverters. This may explain the price difference between various models. Some electronics, such as TVs, may not work well with modified sine wave inverters. Devices like a fan or heater should work fine with a modified sine wave inverter.
When connecting an inverter to a battery you need to consider how much power you plan to use from the battery between charges ( that is, how deeply you plan to discharge the battery). Deep discharges will significantly reduce the life of the battery.
@MD boater, really good points, if I may say so.
You can get a straight inverter or an inverter charger combination.
Also look at the inverter's surge capability as many products differ. If you are thinking of a more powerful inverter that may power a device that surges on start-up, like a compressor the surge rating is very important.
I would only install a pure sine wave inverter if I was going to the trouble of properly wiring it in.
Regarding batteries, some general rules: (assume all of these are very good quality): AGMs can be discharged by 60% about 300 times, Gels by about 80% 1000 times and the new Thin Plate AGMs by 100% about 800 times. For regular Flooded deep cycle house batteries it's less - by 50% about 250 times.
Also, AGMs accept re-charge at about 40% of their AH rating, Gels at about 25% of their AH rating, Thin Plate AGMs at about 300% of their AH rating (yes, you read that right!) and regular Flooded deep cycle flooded at about 25% of their AH rating.
http://rinkerboats.vanillaforums.com/discussion/4526/thin-plate-agm-batteries-vs-flooded-deep-cycle-batteries
What I was referring to above about the different battery jumpers was I found the same exact battery jumper at west marine with their logo and also two amazon with a different company, all at different prices. Maybe west marines is more for marine environment? Links are below:
http://www.amazon.com/Stanley-PPRH5-Professional-Power-Station/dp/B0051SO7JQ/ref=pd_sbs_263_11?ie=UTF8&dpID=418GaaN1YDL&dpSrc=sims&preST=_AC_UL160_SR160,160_&refRID=158668M0EY9CA2SXKNRV
http://www.westmarine.com/buy/west-marine--1200-amp-powerstation-pro--15808520?cm_mmc=PS-_-Google-_-Shopping_PLAs-_-15808520&adpos=1o3&creative=54601695484&device=c&matchtype=&network=g&gclid=CIC-rp6qwMkCFQErHwod5zQFUg
06 Rinker 270
06 Rinker 270
06 Rinker 270
