Why do Bravo 3 propellers get that hard coat of scaling?
LaRea
Member, Moderator Posts: 7,556 mod
Every Bravo 3 I've seen has it. After spending more than a month or two in the water, the props get coated with a thin, crusty layer of fouling, like this:
What is it? It doesn't happen on my dock neighbor's 312 with Volvo composite outdrives, so I assume it's some sort of electrolysis process from the aluminum outdrive and stainless steel props. Can anybody confirm that?
I don't care about the fact that it's ugly. What bothers me is the extra drag from the rough surface. Drag on the surface of a prop has got to be a real performance killer.
The coating is extremely brittle, and it will easily come off with light sanding (50 grit - barely need any pressure). You could sand it forever with 220 grit and it would never come off, but it'll flake off right away with 50 grit. I've also tried a 3000-psi power washer, and that took off some of it, but not all.
People say it can be removed with toilet bowl cleaner, but the ones I've tried did absolutely nothing.
Lastly - is there ANY way to keep it from coming back? I always clean my props to a nice satin shine every spring, but you'd never know it after a couple months. No paint will stick to the props, and I've heard nothing but disappointment from people who have tried various prop coatings and treatments.
Here's what they look like now:
Not to mention, I'd have to reapply every year, which means sanding off all the old coating, which means it's even more work than I'm already doing.
Handy - you go first!
Not that it matters ... I lost interest in Propspeed after I checked the price. The materials alone would cost $500 to treat a pair of B3s.
This is what my props looked like after being in the water at my marina for 2 months.
My XR props were polished to a far better mirror shine that any Volvo prop I have ever seen. That still didn't stop the "coating" from forming. I wonder if Volvo has discovered some sort of cathode system that protects the props better?
I say "probably" because I can't find any test results. Any boat propeller will lose some efficiency if the blade surfaces are rough, but I don't know if we're talking 5% or 0.05%. There's plenty of published data for ships, but I can't find anything for outdrives.
I'd love to hear from somebody who checked their WOT speed before and after polishing their props. Maybe it doesn't make a noticeable difference.
