How do I paint outdrives?
On my spring to-do list before launching is to paint the outdrives. I've never done, though my mechanic suggested it and said there was a product I could get that was essentially in spray can form. Can you provide some guidance as to the best way to do this, including prep, application and product? Thanks much. Drives are twin Bravo 3s.
What's the general condition of the drives? New, old, any signs of corrosion? If there's any corrosion at all, you'll need to sand down those areas to bright metal, and apply a primer and paint specifically made for aluminum outdrives. Be absolutely certain the paint is for outdrives. You can't use hull bottom paint.
Don't use a steel wire brush. Use either sandpaper or a stainless steel brush.
Make sure you mask off the Mercathode (under the drive at the transom) and the trim cylinder shafts.
Your tech was probably talking about Interlux Trilux. It's very popular - not cheap but it's an effective anti-fouling paint. If you store the boat in the water, that's probably the way to go.
If you store on a lift, you'll probably want a glossy paint because fouling won't be an issue and you'll want the drives to look good.
Trilux will work great for you. It'll keep the moss growth way down. If the drives still have the original paint, and you're planning to paint the entire drive, you'll need to lightly sand the original paint. Then apply a coat of Primocon and two coats of Trilux. Paint the first coat a different color from the final coat so you can see what you've painted.
I leave the anodes attached during painting, and then replace them with fresh ones. If you're not replacing anodes, don't paint them.
To paint, start with the drive all the way up and turned to one side. Paint everything you can easily reach. Turn steering wheel all the way to other side and paint. Then lower the drive and paint, then turn to other side and paint. It helps having an assistant to work the trim buttons and steering wheel.
For masking the cylinder shafts, you need the masking to flex as you move the drive up and down. Here's what I do: with the cylinder fully extended, I wrap the shaft with a piece of plastic cut from a trash bag. Then I tape it at both ends like a sleeve.
1) do I need a special prop wrench for that? Or will a 1.5inch socket and a pipe wrench work?
2) should I be removing the props for shaft inspection/lube every season?
Never done this job so any tips are appreciated! Thanks guys.
, wait a day then wax it and buff it with a soft towel. Always touch up chips and scratches promptly.
I do mine every season. Clean and lube the props, refresh the paint, replace the anodes. On the Bravo drives, you really need to stay one step ahead of corrosion -- even in fresh water.
http://www.jmsonline.net/interlux-trilux-33-aerosol-black-yba063a16.htm?utm_source=google_shopping&gclid=CLiYp-Cqs8oCFZOBaQodyRQLxQ
I'm using Trilux, with Primocon as the primer. It prevents growth of moss, which is the main culprit in my area. I'm guessing it's also good for salt-water evils such as barnacles.
In my experience, the durability of the paint isn't a big deal because I always end up repainting every spring. After a season in the water, there are always at least a few new spots of corrosion to deal with. Since I have to clean up the drives anyway to repaint the corrosion, why not go ahead and paint the entire drive.
Excessive? Maybe. I could just touch up the corrosion spots, but I like having fresh paint every spring.
Here is my drives, need paint hey?
One reason is that they are Bravo 2 drives, which never seem to be as bad as the Bravo 3 (the poster child for outdrive corrosion). But the main thing is that you're storing out of the water.
I'll never forget the first class I took in ocean engineering years ago. We got a bunch of identical aluminum plates and stored them in different conditions: dry, damp, submerged in water and so forth. After a couple months, the dry and damp plates had only light surface corrosion, but the unpainted plate submerged in moving salt water was almost gone.
That's what happens to outdrives stored in water, unless you keep up with the paint.
