Anchor Problems, Please Help!
partlowr
Member Posts: 119 ✭✭
I did check out the FAQ's and used the search feature but found nothing specific to my size boat which addressed my specific issue.
First things first, my boat is a Rinker 232 Captiva Cuddy(23.5ft). I purchased a Danforth anchor which has a holding weight of 1300 pounds and says it will work for boats up to 30ft in length. I also purchased a high quality rubber coated 6 ft chain. I have had a number of issues with this anchor not holding in different lakes (Lake Michigan, Lake Geneva in varying conditions from calm to 10-12mph winds. For the record I was with some friends with similar sized boats(my hull might be deeper) and similar sized anchors who were not having any issues. I even tried using a smaller secondary anchor and that did not help. Furthermore running two anchors is a pain in the butt and I spend more time trying to make sure they don't tangle with one another or other people's lines when tied up in a group. I know how to properly throw and anchor and drift and allow to set before line tie off so I don't think I am the problem.
I am starting to think my problem is the rubber coated chain, I think it might be too stiff and not be allowing the anchor to hinge and set. Do any of you have any opinions on the stiff rubber coated chains? Should I just buy some cheap galvanized chain and give it a try? My only other option is to move up to the next size anchor but it will not fit into my anchor locker on the bow of my boat. Do any of you guys out there with 23-24 ft Captiva cuddies have similar issues? What type of set-up are you guys using that you are having good luck with. Should I move away for the Danforth style anchor for my boat?
Even though the Manson is a ton different in shape from the danforth it should fit into your anchor roller. Mine fits snugly.
If the others are having success with Danforth or similar anchors, then your rode might be to blame. As @Black_Diamond said, a Danforth will only reach its rated load when it is being pulled parallel to the seabed. To make that happen, you can: add more chain, use heavier chain, let out more anchor rode, or all of those things.
Of course, adding too much chain weight can make life difficult if you are hauling it in by hand. It can also affect balance and handling.
I feel the pain of the OP. I could never get my anchor to grab on my 232. The Allegheny river outside PNC Park is a popular place to anchor out and enjoy the ball game replays and I would always have a tough time with my 232. With my 280, I can drop the anchor in fast or slow current and it holds like a dream.
BTW........ A when calculating the depth of the water to calculate your scope ratio you must count the distance from your bow pulpit roller to the water+the actual depth of the water, so maybe like this:
6 + 14 = 20 x 8 = 160 feet of chain and rode required
So much to learn......whats that?
Thanks! Never heard of it
