Looking for some input on a two issues...
last year, on a long trip, I noticed my boat was listing to starboard quite a bit while under way. I could correct it somewhat by giving it full trim tab on the starboard side , but not completely. As soon as I came off plane, it leveled out. Friends were saying one fuel tank was full and the other was empty, but that wasn't the case. Turns out, I have two sets of trim tabs underneath. One I can control and the other that is stationary and always in the "up" position. A bolt had backed off the support for the stationary trim tab and it settled into the "down position" Easy fix. we just wire tied the bolt into the position that the other one was in. However, the question remains in my mind, why even have a stationary set of trim tabs. Do any other sizes have two sets of trim tabs, one movable and one stationary ? And what is the purpose ?
Also, if you take a good look at the pic of my boat, it seems (to me at least) that my swim platform is very very close to the water (especially on the port side, in this pic, you can make out the way it slopes to the port side), and it doesn't matter if its full of fuel or not. It does come up out of the water when on plane, however brochure pics show the platform out of the water and not touching while the boat is stationary. Again, some advice that was passed my way, was that the Volvo Penta IPS diesel drive, weighs more than the 496s and brings the stern down further, this still doesn't explain why it lists more to port ...
(Al, please feel free to chime in anytime !!) I believe the brochure photo below, depicts the way the platform should sit.
here is a picture of a 390 with diesels and a 420 without diesels:
I looked it over really good, it looks as thought there has never been any damage, such as "backing in too hard to a slip" or anything that may have bent it down, It appears to be in good shape ...just slopes down in the back. Thanks for those pics !!
Im not not a 100% sure relocating the battery bank would do it, and then the other problem starts, where would I put 6 batteries ? They take up a lot of room !
"With the Volvo’s, your boat will sit low in the stern due to the additional weight, and also due to the hull running surface modifications required by Volvo for the propulsion (IPS) system".
At least I know now that there is not a structural issue or prior damage !
Handy : Mileage......uhh, OK :-) My boat is ALL DONE at 3500rpm...nothing left ! ! Getting there is a breeze though. She's a heavy girl at 24,500lbs dry. But she moves well through the water. Not much upsets her and wakes from other boats, similar in size and smaller are hardly noticed. I have found that 2800 to 2900 RPMs is the sweet spot. There is no trim on the pods, so there are no adjustments to be made. At those RPMs, I am at 24mph +/-. There is no great loss of mileage if I bump that to 3100 RPMs and I might go up about 5mph. After that, the mileage starts to drop off. My best mileage at 2800 RPMs is about 12.5 GPH X2...or 25 GPH total.
However that is NOTHING compared to the Smiles per Hour I get at just about any speed !!
& now that you can boat year round, I expect you to put at least 100 hours on the boat yearly. At that point, I might be able to say you 'actually' use your boat more as well. It's funny how yes, I burn more fuel than the majority on this forum...& use it more than most...& the one that uses his the least...burns the least. hmmmm....
& Dirty, your numbers are about right in line with what I'd expect. There are 2 390's I boat with that have diesels and they burn about 22-24gph at around 28mph. & I agree, the smiles/hour is what matters!
PS........ Anyone watching Trump Tonight? Around the pool here in Phoenix he has HUGE support!
