Tri-Color LED Lights For Arch, Swim Platform OR Hardtop
We have discussed these before but there are a lot of new guys on the forum who are customizing their boats and we are all thinking of winter projects.
This up-grade is cool and not that expensive. The tri-color (red/white/blue) led lights replace the white lights that are oem from Rinker. In fact both my 2013 EC 310 and 2014 EC 360 came from the factory with the tri-color lights already installed.
I am also going to replace the white swim light on my swim platform with one of these so that everything matches. I really like the effects and if you want cockpit lights on while underway the red lighting does not reduce your vision which is cool.
They are very easy to replace on most Rinkers and not even hard to start from scratch, if you have no lights in your arch. They are 2" in diameter and have 2 wires. For some installations they will just be plug and go for others some basic wiring might have to be done.
They are super energy efficient - white light is .46 watts and .036 amps. The red and blue are .26 watts and .022 amps. IMO that is crazy low and won't run your battery(ies) down worth talking about. They produce 20 lumens. The white is quite bright - good for looking for things. The red is very cool as is the blue.
If interested here's the Info:
You can order them from ITC Marine 1-888-871-8860 or any supplier. I'm sure ITC could easily give you à dealer's name for your area. BTW The ITC Marine website is real cool, they make so many great products for many marine applications from lights to taps.
ITC Marine PN:
Stainless Steel Bezel - 69660SS -RBW
White Bezel 69660W1 - RBW
You can also purchase them at Overton's and have them shipped to your door. They sell them for $39.95. They sell the SS model. You can view them on page 146 of the 2015 Overton's catalogue or on line and contact Overton's order desk at 1-800-334-6541
The Overton's PN is 733104 and they call it an ITC Tri-Color LED Light
For the price it is a huge custom effect - I get so many compliments when docked at different marinas. When I add the new tri-colored light to the swim platform the effect will be even better.
Ray
2006 390
Previous 2000 340
@diggin' I believe you are 100% correct. They usually measure the lumens off the white which is considerably brighter and you can also see the difference in the power draw. While the draw of the white setting is usually quite low on an LED it may be twice as bright as the red and blue. For a comparison - on the ITC lights I have, the white is as bright as I would want in my cockpit at night. The blue is next brightest and the red is the least brightest. For your reference, I believe the ITCs are rated at 20 lumens. For the Admiral and I the white is plenty good enough to see anything in the cockpit area - also we don't want it so bright that it draws every bug for 10 miles to the boat. The blue is very nice just to sit under and have a drink and draws many compliments. The red is also nice and draws lots of jokes......if you know what I mean LOL
Suggestion ....purchase one of the ITCs and try it in your garage. That should give you come kind of idea before you buy the more expensive lights and start drilling and wiring! If you don't like it send it back. Heck you could even buy one of each to compare and return the one that suits you less?
It's all good fun, right?
Our swim platform there also on board and in the cabin
I also ordered a BlueSea dimmer module(which I didn't install yet)... The Lumitecs are controlled by a regular on/off switch. When you initially turn them on, they're white and ramp-up in brightness... A quick flip (off/on) of the switch and you can select the brightness that you want. If you let them ramp-up all the way, then give them a quick flip (off/on) then they go into color changing mode(constantly changing). With a quick flip(off/on) they'll stay on that color. I am going to wait until it gets dark outside and see just how bright the "colored" lights are... Might just return the dimmer if they're not too bright. Here are some pictures of the lights(they're a bit dirty... Will wipe them clean when the cover comes off!!)...
old lights:
New lights:
http://www.theliquidlite.com
All those lights (spreader and transom lights by ITC didn't take more than 30 minutes to install, less than 10 minutes each. That's what I like the most about them.
I can switch between white, blue and red by toggling the switch on and off.
