Trying to fix a small hole with Spectrum gelcoat paste patch question from Newbie!
Hi Rinker family, first let me say I LOVE my 2005 Rinker 250 FV, it has been a great boat for the family and me!
I love this site great info. I was hoping someone in the know could help me find out what color the interior fiberglass on my boat is?
I am trying to fix a small hole by the back seat on the starboard side. I haven't done this before but I was going to try the spectrum gelcoat paste patch and. think the color is light beige or a bone color but not sure. Did the 250FV from 2005 have different interior colors? Also has anyone used this stuff and is it appropriate for the job?
Any help or tips would be greatly appreciated!
Thanks!
Here is some pics to show what I am talking about!
Neil
You might just cover it with a slim quarter sized plastic knockout filler painted white (or use a skinny starboard slug) and glue it on with a bit of 5200. Nobody but you would ever notice it down there.
Just a thought. Mike
EDIT: Hey welcome to the forum.
I start by beveling the edges of the nic or gouge. I use a cutting bit in a dremel tool. The bit looks like a small round ball, with file grooves on it. I use it very delicately to bevel the edges down to the fiberglass. Next, clean the repair area with acetone. Next, apply masking tape around the area to be repaired. Mix the hardner with the gel coat per manufactorer instructions. Apply the gel coat using a body puddy spatchula. Make the gel coat flush with the masking tape surrounding the repair area. If the repair is deep, it might take two applications (coats) to build up to the proper level. Once the gel coat is cured, begin wet sanding (use a sanding block) with 400 grit paper. Once you start to get down to the tape, switch to 600 grit. Once you've sanded the masking tape off, switch to 800 grit, then to 1,000 grit. Be sure to keep the paper wet at all times. Once your done sanding, apply some 3m paste wax, and buff. I've used this technique and after I'm done, even I can't tell where the repair area is. It's very easy. If I can do, so can you.
ya....but they want $28 for shipping. Twice the product. What gives?
