Prop Question, hard to get on plane
                    Boat is a 2000 Rinker 242 fiesta vee with a mercruiser 350 mag MPI. Outdrive is a Bravo 3 with 24P props. Boat seems hard to get on plane with just two people and even tougher with more. I have to drop my trim tabs all the way down and go full throttle to get on plane with just me and the wife on there and about 3/4 tank of gas. Getting more people i have to shift weight around and move people up front to get on plane. I know this isnt a very big or heavy boat and the motor should produce a good amount of power with that outdrive so just wondering what your thoughts are on either changing the prop to something else or if maybe i have another issue somewhere. I really dont want to change the props out due to the cost, but if i did i want whatever will get me on plane fastest as im not worried about top speed at all just as long as i can cruiser ontop the water.
Thanks for any insight!
With the mag & BIII, I would think that it would pop right out of the water with just 2 people on.
I just pulled the boat out of the water and noticed that there is quite a bit of water that sits in the bilge. The bilge does run quite often to pump water out so i assume i have a slow water leak. I wouldnt think this would cause an extra weight issue which would prevent it from having the power like it should since the bilge pumps it out.
Also read on the drive that it is 2.20 ratio.
I replaced the shift cable awhile back and dont know if thats when i the issue started or not as its a new boat to me and didnt notice the issue prior but never had a chance to have it in the water for very long before i replaced the cable. i did tighten the clamp on the shift cable bellow a few minutes ago to make sure it isnt the problem but didnt see water coming through there but the water level wasnt high enough in the engine bay for that.
Also, i notice on the front of the outdrive lower piece is a hole where exahust comes through. Not sure what its there for. Ill go grab a pic real quick for reference.
Thanks for the help BTW i really do appreciate it so much!!
how did you tighten the clip on your shifter shaft bellow, there is a kind of special tool that is easy to do to make sure that the clamp stay round and not squeeze. If you need more info let me know.
Paul
to be best quality for price. I'm happy with them thus far. Plan to go out this weekend for our first full day out so we will see how it performs but I'm very optimistic.
