Prop Timing/Torques specs
MIKES342
I wanted to share some information I received from my dealer pertaining to the torque ratings and the timing of insalling the bravo 3 propset. When looking at the props from the rear. The front prop nut is torqued to 100 ft lbs. The rear prop nut is torqued to 60 ft lbs. Also the timing is as follows the leading edge of the front prop is at 6 o clock and the rear prop leading edge is at 12o'clock. I hope this helps someone
appreciate the help.
06 Rinker 270
torque values as noted are correct.
Yes on the prop timing.
06 Rinker 270
06 Rinker 270
06 Rinker 270
06 Rinker 270
Craigswardmbt, i'm in central ct, I usually launch from a club ramp in Cromwell, on the CT river, unless i'm going out in the sound, then I launch in Old Saybrook. I see a few Rinkers on the river.
Sorry for the hijack.
