Car Wax vs Marine Wax
I been told by some boaters they use high grade car wax to detail their boat. I always use marine wax because the gelcoat is porous vs the clearcoat on a car which is not so porous. Is there really big differences between the wax.
Bayrunner -- FV312 - Simple Pleasure
Best Answer
Bayrunner Member Posts: 177 ✭✭✭
Thanks everyone for great advice. Here is the outcome of using Mother's wax.Bayrunner -- FV312 - Simple Pleasure
I would recommend an orbital polisher with foam pads for polishing or wool pads for compounding. wax can either be with a foam finishing pad and the polisher or by hand.
I would recommend at least doing a polishing step and then wax.
Think of it this way: polishing is mechanical process that removes material from the surface, while waxing is a chemical process that adds material to the surface.
(now that I dropped that little bomb, I'm just gonna watch for a while... yes, I'm evil like that)
I tried the compounding... never again... i have a box of 2500# waiting for me now.
I used a DAP (dual action polisher) to apply both products. With the polish I used a light cutting pad, and I'm VERY impressed with how well it did to shine up the boat and remove light scratches and water stains from the Texas lakes.
With the wax, I used a finishing pad and it went on and off with great results, leaving and very deep and wet gloss. I typically use commercial grade 3M products but this stuff is amazing and I'll never use anything else ever again. I can assure that nobody would ever guess it's a 13 year old boat, as it looks as good, if not better, than new.
http://forums.sbo.sailboatowners.com/showthread.php?t=117266
06 Rinker 270
