carpet replacement/seat changeout
ortiz_1989
Member Posts: 7 ✭
Hi everyone I'm new to this so forgive me if I'm posting in the wrong forum. I'm wanting to change out the carpet in my 2002 rinker 180 br. I'm wondering if there is anything I should expect? is it hard would I need to change out the plywood etc? any info would be great. Also I am wondering since I have back to back seats on the driver and passage side can I change those out to a single bucket seat on each side? wanting to make more room to put stuff and what not. And the last thing where can I get new decals I'm looking for all new decals for this boat. wanting to fix it up a bit. Thanks!
Hey @Ortiz_1989, Welcome on your first post and to this forum. You will have a great time here and make many friends!.
I have changed the carpet on a Rinker 190. it was glued down. We scraped it off, which took most of a Saturday. We sanded-off the residue, tack ragged the surface and sealed it with a coat of modified and thinned resin, let it dry and glued down new carpet. it already had bucket seats.
However I did replace the slider seats in a 1990 VIP vision. The trick was to mount them securely into the plywood floor as there is a stronger pivot point on captains' seats. I don't remember what size screws we used but it lasted years before it was sold.
You should be able to see in the bow or engine bay how thick your wooden floor is. If you can not find a place to determine the thickness of your plywood, cut a piece of coat hanger about a foot long, put a small, about 1/16" 90 degree bend in the end of it and slip it down a screw hole from the old seats - move to towards a side of the hole and pull up. When it stops mark the wire at the floor height. To remove it center the wire or just pull hard - that will be your floor thickness.
That way you can determine screw length but more important screw width as thicker ply will support a thicker screw or one of the new pop through fasteners.
I am sure you will get more good advice on your question from other members on this forum.
Going from glued down to snap in carpet is a real PITA. You are going to have a hard time getting all the old glue off the floor/gelcoat. It can be done, it will take lots of sanding with a DA sander but you will most likely have to spray down a coat or two of new gelcoat to get it back to a nice finish afterwards. Check out www.snapincarpet.com they might have an existing template for your boat or they will custom make you exactly what you need. For graphics I would check out https://www.racelinedigital.com/store/index.php?main_page=index&cPath=89w I just had them do some new vinyl graphics for my boat and they turned out great and at a very fair price. here is a before and after photo of my graphics. Good luck and enjoy your boat!
