Bravo III raw water pump
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
pulled my raw water pump yesterday from my port engine that had overheating issues at the end of the season. Will replace it with a SS Hardin Marine pump. Pic attached of the wear on the back of the pump (hose connection side). This fit the bill for wear to cause water pump problems?
Best Answers
OptionsBlack_Diamond Member Posts: 5,439 ✭✭✭✭✭Confirmed today that the water intake hose was kinked at the transom. I was told Mercury now has an upgraded kit for this to solve this problem.Past owner of a 2003 342FV
PC BYC, Holland, MI -
OptionsMichael T Member Posts: 7,227 ✭✭✭✭✭On water flow restriction the order I go is: sender or gauge problem (ground or R/Ohms) intake hose, exhaust flapper, water pump. I have heard of so many hose and exhaust flapper problems for Mercury, Volvo and OMC that I look there before a water pump tear down ....unless the impeller hasn't been changed for years.
OptionsBlack_Diamond Member Posts: 5,439 ✭✭✭✭✭For anyone interested, copy attached of the info for the 'upgraded' raw water intake hose assembly for the Bravo outdrive. The part of the hose that goes into the transom is now a hard plastic piece. Guessing the kinked hose problem I had was not unusual. Hope this is a good fix!
OptionsBlack_Diamond Member Posts: 5,439 ✭✭✭✭✭@MD: I had to replace the raw water hose that goes from the outdrive bellhousing through the transom.Past owner of a 2003 342FV
