270 Aft Filler Cushions Wanted - or make?
                    Hello,
Looking for white after filler cushions for my 2006 270. If anyone has any for sale or knows of any please let me know.
If I cant get them, I know some of you have made some. How? Did you get the vinyl from Rinker?
Thanks everyone
Thanks everyone
Patrick
06 Rinker 270
      06 Rinker 270
lip... It'll look kind of hoaky!! Any suggestions?
As usual I have spare parts LOL so I dug these up to show what I was talking about in my earlier post......These are the rubber bumpers that I used to use as stoppers for the legs of the aft filler cushion on the fiberglass ledge for the aft filler cushion "legs" on my EC 360.
Of course I did not use the puny screws that came with them. I substituted better SS screws, pre-drilled the holes and applied 3M 5200.
Rubber is nice as it holds the metal legs well via friction, has some give to reduce stress on the legs and the leg's holding bolts, is inexpensive and a "right off the shelf" readiness and is real easy to use.
BTW I put a small SS washer in the hole on the top of the rubber stopper before inserting the SS screw to spread the stress.
They have worked wonderfully and took less than 15 minutes to install from initial measurement to final clean -up.
If using this method do allow 48 hours for the 3M 5200 to cure before placing a load on them.
Also how did you make sure the vinyl was matching in color?
06 Rinker 270
Home port: Hammond Ind.
The sewing machine is a whole new animal. Almost bought one to repair my winter cover myself but ended up getting it fixed. I'm guessing you need a heavy duty machine rather than your household machine?
06 Rinker 270
06 Rinker 270
Is Marine grade plywood necessary even if its completely covered? Read somewhere that pressure treated is acceptable and others say not.
06 Rinker 270
How did your son in law get into that business? I bet thats fun.
06 Rinker 270
Lessons learned during this project:
1.) Don't be a wuss... It's only a sewing machine! I was hesitant to even try it, but I'm glad I did.
2.) Tight radius corners are very hard to wrap in vinyl. I should have made each corner with a larger radius(just like the oem!).
3.) Always color match vinyl in direct sunlight!!! This vinyl looked perfect under my white winter wrapping, but it is obviously too white. Hopefully a few weeks in direct sunlight will change its attitude a bit.
@MarkB ....agreed, I think you did an amazing job!
