Old Fuel an Issue?
rogrogers
Member Posts: 2 ✭
Due to several circumstances beyond my control I didn't use my 2007 Rinker Captiva 226 the past couple of years. I've got three year old gasoline (about 25-30 gallons in the 42 gallon tank) that is probably E10 ethanol that I'm pretty wary of. I did use StaBil when I stored the boat. Any suggestions, gang? If I did need to drain the tank what is the best method?
intercept the fuel line to the rails, use either a barb fitting, or, use a hose with an interior diameter the same as the outside diameter of the existing fuel hose and a clamp, and hit your pump with 12vdc charge- pump it into containers that can be properly disposed of...
stabil is pretty good stuff, but three years on E10 is asking a LOT from it... if it smells like varnish, don't even bother... the ethanol is a solvent to begin with... I'd be concerned about what its done to your tanks soft lines, too, in those last three years.
