Eyelet replacement with 5200 sealant
Hi,
I have a 2013 290ec that the U hooks (eyelets) in the transom have rotted due to being partially submerged and not sealed well. This resulted in rust streaks inside the bilge area.
Rinker sent me the replacement eyelets but I'm to find someone who can replace them. They said all you need is to replace and seal with 5200 sealant.
I'm considering doing it myself but have never worked with 5200 nor replaced these eyelets.
Anyone have any experience and or tips?
Thanks,
Art
    Its basically caulk. But once it gets on a surface its almost impossible to get it off again. Make sure you caulk from the inside as well.
    Boat Name: Knot A Worry
    4200 above water and 5200 below water. Should be fairly easy. Clean surfaces well
    Simple to do Its just sticky water proof caulking, Put it on inside and outside, You may have to have a beer drinking buddy to hold it on the outside while you attach the inside. It does not want to come off your hands very well. Good stuff. Your boat probly needs to be out of the water. keep some rags handi.
    It's just like silicon caulking.  Just use ample amounts of it. In fact squish some into the hole before you put your bolt through and then ample amounts around. Wipe off any excess, but leave a good area (like 1/4" around the U bolt bases) to make sure it is well covered.
    Also wear gloves and old clothing. That stuff gets onto your hands, good luck. It takes days to get it off.
    I like Steve's advice or Sikaflex. I have not found that silicones stick as well to fiberglass or gelcoat.
    Mineral spirits for clean up.  Tape off the area around the outside area.  5200 is the best but can be very messy to clean up.  The tape will keep the surrounding area clean and professional clean lines.
    MiamiAGMiamiAG Member Posts: 210 ✭✭
    Thanks. Now I just need to work up the guts to do it...
    summerxsummerx Member Posts: 211 ✭✭✭
    my first thought is was there any water entry into the transom from those holes?  I can't imagine that the holes drilled are sealed/fiberglassed prior to putting the  Ubolts in?  make sure the there is no dampness or in my mind, could result in rot over the years.
    Was playing with 4200 last weekend when I was mounting my underwater lights. Got some on my forearm. Needless to say, its still there 9 days later lol
