Removing caulk/ port side hatch cover- 342
Wildboating
Member Posts: 957 ✭✭✭
i am trying to remove the cover on the port side to access the door tracks for repair/cleaning. I have the screws out but the caulk is like a permenant weld to this panel. Is there a trick to getting this panel off aside from heavy prying? I'm afraid the fiberglass will break.
You will have to buy a couple cans of Anti-Bond which removes polyurethane adhesives...5200 is a polyurethane adhesive. Here is a link.
http://www.westmarine.com/buy/anti-bond--anti-bond-2015--P001174804
That's a good point. Will anti-bond pentrate the filling, or do you remove some 5200 and then re-apply the anti-bond?
I ended up shimming the bottom track up and adding washers between the door and train's on the upper track.. The door FINALLY slides easily! So glad to have that black grease out of the track and it working with one hand. The PO had put a graphite grease in the door tracks which ended up everywhere and was so dirty / dried up.
