Drive Shower
I ordered a Sport Tech Drive Shower from CP Performance. It looked great and would have bolted up to the the B3 drive but would not clear the boat or the swimm platform (04 232) . Damm. so sordered another. This one was was also ordered from Cp. This one was a product from Wicked Marine. bolted up great.No clearance issues.
We recently went on a long trip tp Nevada and did some somewhat long miles.About 150 or so in 4 days. No drive issues so I guess the proof is in the pudding. I will be posting some awesome pics soon.Stay tuned.
How much is a good time worth?
My guess is most drive showers out there have the possibility of getting pluged at some point.
I guess I look at it like somewhat cheap insurance. On longer trips at speed wth the outdrive trimmed up I have read and heard of people doing damage and even burning up the upper end of their B3 out drive. That would not be the high point to any boating day and cost several bucks that could be spent on go juice or a number of otherthings. To me it was worth the money and time.
Just put mine on so its non stop full speed to key west Friday.
Mine had burrs..more like chunks of metal..at all the holes. If you hooked up a hose to them to would be massively disappointed. What spray you get is worthless. I worked on mine to deburr with little success. 98% of the water sprays at an angle that does not even hit the drive, the other 2% zero water came out of (the water goes right past the hole. I'll put the new ones on, but I still think they are a scam.
One thing a lot of folks at my dock have been discussing lately is a ti bar. Anyone using those between the drives?
If it does half of what it reports to, I'll be happier... I run an Alpha-g2, and they don't have a lot of reserve oil or exposure to the water when on plane- I'll also be twisting that thing with more torque this season... If my lil rig was any bigger at all I don't think I would have bought it with the alpha... I hesitate to run more than an hour or so above plane without slowing down and dunking it, letting it cool for a few minutes.
If I had one of the bravo series, I wouldn't worry one bit about a shower- they have enough reservoir and gearbox exposure that even simple heat transfer to air will suffice... not so much with the tiny upper on the alpha...
I ran a brand new Bravo 1 with my 390 HP 383 for 1 hour without a drive shower. It had chalky deposits on it even after that time. I cleaned it off with 5% white vinegar. Waxed and polished the drive and installed a drive shower before the boat went out again.
That was about a dozen years ago. the next owner who bought it from me beat the cr*p out of that boat and rig and it's still going strong.
For ANY up-powered Alpha or ANY fast run bravo I'd install a drive shower(s).
By FAR the cheapest insurance anywhere.
A job most owners can do or any decent tech in 30 minutes.
No, I would never say don't use drive showers on a cruiser.
Many drives on cruisers could probably benefit from drive showers, based on the condition of drive towers I see in marinas.
In many cases I suspect significant drive overheating not from high speed running but low speed loading or even lugging for long periods.
imo it would depend very much on use and observation. IMO personal observations of each person's drives is the critical determinant as IMO personal usage is the key.
Is the boat heavily laden with friends and just on plane for long cruises? Is nit run at high speeds/rpms for long periods? Is it wot'd for 30 plus minutes? So, IMo "it all depends"
I never saw any signs (even the most minute and un-noticeable) on the twin Bravo lll drives for the twin 350 Mags on my 2013 EC 310 or the Bravo lll X drives for the 502 Mags for my 2014 EC 360.
Nor did I ever feel heat build-up after stopping after a long run and going immediately into the water to check.
Had I seen deposits or felt overheating I would have immediately ordered drive showers.
IMO any lime-like or chalky-like deposits on drive towers bespeak drive tower over heating and require attention.
IMO a drive shower(s) are cheap and easy to install and as such are ridiculously well spent insurance for such expensive equipment.
....and man do well designed drive showers work. A friend videoed my 383/Bravo I combo (yeah it was that long ago that a video camera was used lol) and by the time the boat was on plane the water was blasting all over the top of the drive tower.
I would run that drive at 50 to 70 mph for hours and it was shiny and black after that without a trace of deposit on the drive tower or anywhere on the drive and the gear lube was always pristine.
BTW if I had Bravo lls I'd be using drive showers for sure!
one alpha behind a 24' (3500~3800#) fiberglass boat is working its a$$ off... two behind the same boat, not so much... one Bravo would be well in it's comfort zone behind the 24' fiberglass boat, but would strain likely at around 5k#'s in single application... a B3 likely not as much... a pair of B3's will likely handle upwards of 15k# boat w/o concern, so long as it wasn't running WOT or crashing through faces of waves constantly, loading and unloading...
if those showers were necessary I'd guess they'd either come stock, or the OEM's would have devised something that does the same thing- which to me speaks of us boaters simply taking precautions and overbuilding, or, somebody taking something out of the design envelope and using it anyway...
most mod's we do are either or, or either because of or- meaning we take precautions and overbuild an identified weak link, or, we overbuild a weak link we actually created by pushing something else to the edge of it's design...
this is sorta like the oil debate- there is what the manufacturer recommends, going as far as to void warranty if something else is used, and all the while not knowing how you actually use your rig... they can 'guess', based on make and model, and how it's rigged- but they don't KNOW.. not KNOWING, they leave a huge market for aftermarket sales- which we take FULL advantage of... and by my reckoning, the shower fits in this category... I don't think I NEED it, but I can't see how it will hurt anything (if it functions as advertised)... same with the bypass motor oil and then transmission oil filter on my truck... I don't think I need it, but I can't see how it will hurt one way or another- in contrast to traction bars on the same truck... I jumped the TQ to twice the delivered rating, and those poor UBolts that hold the axle to the leaves and shackles that hold the leaves to the frame just weren't enough anymore... I HAD to put traction blocks on to cover my created issue... not so much with the filters... see where I'm coming from?
