Fiesta Vee 250 Pump will not stop running.
sdholzhauer
Member Posts: 22 ✭✭
I filled my fresh water tank and have turned on all of the faucets to get the air out but the pump will not turn off. Am I missing something to get the pump to stop running? I have only been on battery power so far. I have turned the hot and cold at all sinks and none of them are spitting air.
If you can hear the pump motor running, I had to prime the pump by filling it with water through one of the pump pipes and siphon the water through on the outlet side.
