2006 342 - Need help to find leak
Hedge
Member Posts: 24 ✭✭
Hi Guys ... I need your help. We bought a 2006 342 and just got home from a ten day trip getting it home (Lake Champlain to Trent Severn) boat ran great and we are very pleased with it but after a couple of days we noticed the carpet was wet in the aft cabin storeage locker. So I checked, sea cocks okay, no abnormal amount of water in bilge pump areas and water pump not coming on occasionally to indicate a leak in the system. Had a small wet vac so each night I vaccumed out the locker and would get about a quart and thought I was okay to get home. The Galley has a wood floor and now we are seeing water coming up the wall of carpet in front of the head. So doesn't my leak have to be on the drain of either the head or galley sink or vacu flush system for the toilet? So finally my million dollar question, how do you access these areas to check the fittings? Many thanks in advance.
A/C pump and hose/strainer
toilet strainer/hose
bilge pump under the aft bed.
Behind the 'shelf' in the shower you can get to the toilet pump and the hose exits for the shower and berth pumps too.
