342 toilet prime issues
When I put the boat in the water 2 weeks ago I could not get raw water to pump to the head to flush. Disconnected at thru hull and filter, no luck, ended up using a garden hose to force water and it finally primed and worked fine at the dock. Today we made our first run, 40 miles, 2 hours dock to dock. Toilet lost prime again and so I'll need to get out the garden hose again. Anyone else have this? Ideas on a fix? Thx
    You have a loose connection somewhere
    Could something be blocked in thru hull fitting?
    2002 Rinker FV 342
    Handy I'll check connections at the pump. The thru hull, filter and head connections are tight. Bella I had a ton of water coming in before today's ride. Has anyone ever had the pump go? I believe it is a "par max 4". Wondering if it's bad and can be rebuilt.
    So I went over the system and found a crack in the strainer. Was excited to find the priming problem. Replaced it with new strainer, re primed, and after just a short idle to the gas dock it still lost prime. Connections are all good, I opened the shower shelf and checked the pump connections. So I tossed in the towel and ordered a new par max 4 pump rather than keep fusing with it. Probably the valves or diaphram are bad. Hopefully this is it, no clogs.....
