Windlass Question
Hey guys, I got an e.mail from Bryan. We have been troubleshooting an ornery windlass.
He has tried to make it drop by having one person push on it , carefully, while another depresses the down button.
I have always used the windlass to bring-in the rode and chain so it should be stacked properly with no hang-ups. I guess if the rode fell "funny" it could be jammed-up under the windlass with a kink or knot? If so I guess the mirror in the front berth and the access panel behind need to be removed to check the rode?
I am wondering if the tension can be adjusted - the gypsy? the fleming and screw? or using the handle to manually drop the anchor in case it is just temporarily stuck in place? - my guesses
It gets electricity and will move a link or maybe to but no more. Are there motor winding contact brushes that can be easily inspected?
Is anyone thinking ground?
I suggested calling the manufacturer or looking at their website for trouble shooting suggestions.
I have never had trouble with it before and never used it to move the boat forward so it has not been misused. If anything I may not have used it enough.
That's all that I can think of.....
Any suggestions appreciated. I don't have the manual with the amps. and other data but Bryan could supply that.
Thanks MT
ornery windlass. Does not bring anything on the internet......
I called some friends and looked at "windlass binding" on the internet and got nothing more than what I posted above ...but the guys on this forum have such deep experience that I figure someone has this one solved!
@frenchship, ornery=pita
The chain is not jammed I can loosen the end cap and freely spin the gears but when applying power with the buttons it just clicks. Once and a while moves a link or two-very slowly.
It looks spankin' brand new, just like everything on the boat except for the captain.
Headed out to the boat now to give it another try.
looking for a good 12.5 to 12.8 volts
Is the gypsy nut tight. I know the tension nut on mine loosens up occasionally. It won't go up or down when that happens. Yours is a different mfg than mine so I'm not exactly sure of the gypsy design. Mine has a single large, maybe 1-1/4" inch, nut on the starboard side of the gypsy.
If its not that it sounds electrical to me. Or perhaps a bound gear.
My mirror is held on with velcro, then a round hatch to twist open...it is super easy.
MT, Now it's time to start up the blender!
.....yes! Blender time!
BTW, I'm very upset that you are having problems with this windlass. I feel awful that something I sold is not 100%. For the life of me I can't figure out what it could be as it is so new, was never treated rough and worked. Maybe it's my fault for not using it enough.
It has to be something simple. Some kind of adjustment?! I seemed to remember reading in the manual that there were adjustments but that could be my imagination.
Just be very careful with your fingers. That windlass used to be very fast and if something is hung-up or stuck and it suddenly frees-up and takes-off it could draw your fingers into it.
Question: Were you able to use the hand crank? Did it move freely with that?
JC290- all electrical connections on the system are good.
Frenchship- I'm not sure where the solenoid switch is at and have not found it,I think it's built into the unit. Maybe ? Checked electrical current and it's 12.9v
Shawnmjr/Summerx- I will be reaching out to the manufacturer to inquire about the warranty options if any.
craigswardmtb- it's a (Quick Genius) brand windlass and the tension hub doesn't help the motor whether loosened or tightened.
NavyCTRC- the access to the windlass and chain is very similar to your access
Thanks
IF there is no noise a t the boat and you have the engine hatch up - try to activate the windlass from the helm then you might hear a click (for the solenoid) either in the engine bay or at the helm. If this doesn't work go to the front windlass foot controls, open up the windlass locker cover and activate the foot controls to see if you can hear a click down just below the windlass - you could also have someone in front of the Rinker mirror access plate in the front berth to see if they can hear a click deeper in the anchor locker.
Good call telephoning Quick! Hopefully Rinker has a "standard" place to locate that windlass solenoid!
Wow Bryan, I'm impressed (but sorry too) you haven't had the boat that long and you have already been somewhere in it that I wasn't and you didn't want to be.
The hot wire coming into the solenoid looks plenty big enough to deliver the amps - which your meter showed it's getting.
There aren't any visible scorching marks which is good.
What a BS place to place that solenoid! Man, it must have been a bugger to get it out!
Do you think it is just a bad part?
It doesn't look like it was getting wet!
On the positive side the rode/chain looks like it has a nice fall and there may even be room to lengthen the rode if you want deeper anchorages.
