Connecting navigational lights
2003 34 ft Rinker. When installing new navigational lights I accidently pulled a wire through the deck. Now I need to install a new wire but need to know how to get below the deck to make this connection.
Best Answers
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
If it is a 342, those bow light wires are a pain to reach. Go thru the deckplate behind the mirror at the v-berth.Past owner of a 2003 342FV
PC BYC, Holland, MI -
Cableguy Greg Member Posts: 5,077 ✭✭✭✭✭
When I replaced mine with LED's, I had to loosen the sealant with a Phillips head screw driver. I was able to pull up enough wire to get to the splices and replace the housings.2008 280 Express Cruiser, 6.2MPI, B3, Pittsburgh, PA "Blue Ayes" (Sold)
You may be able to completely remove the navigational light housing and hook the wire with a piece of coat hanger with a hook at the end. If not I fear you will have to remove interior headliner trim or if lucky access via the anchor locker depending on model.
Now when I install the new nav lights I will need to run a wire from that connector, add spade connectors to the wires and run them thru the deck hole to the new light, then fill the hole again with silicone, both on deck and in cabin.
I will need to do the same to the port side but this time I know where the light is.
As I do the work I will take pics and post, maybe it will help someone else with a 270.
