Power Trim Res
elarson5757
Member Posts: 232 ✭✭
2007 246CC w/merc 350mag and bIII. What's the correct power trim fluid and does the reservoir have a fluid level fill mark? I can't get my big **** down there to see how full it's supposed to be, only that the res is about 1/2 full or less all be it has been from day one of me having the boat.
I was thinking the same way you are until I went out and actually looked. I googled it as well to confirm and everything Infpund said check the level with the drive all the way down.
I just went went to confirm in the driveway and there is about a 1/2" difference in the fluid level from down to up with the high fluid position being at full down of the drive.
