Return to slip and Ac shows reverse polarity on shore power.
rulives
Member Posts: 8 ✭✭
My 2000 Rinker FV 330 is showing reverse polarity for the AC while in shore power. Same old slip, read dock boxes, swapped cords, checked breakers at the house panel, still no joy. Read back side of shore power plug, all connections appear good. At a loss, any help would be greatly appreciated. Out in the middle of Kansas, not a lot of large cruiser technicians around.
wired correctly....
Hot to neutral 120 v
Hot to ground 120 v
Neutral to ground 0 v
On a standard 15 amp receptacle ....
short flat blade = hot
tall flat blade = neutral
neutral and ground are the same potential.
Hopefully this helps
You can do this test with the cheap neon lamp testers.
I'm sure with your expert advise his problem will be fixed in no time.
Oh man, you guys are killing me. You know, I've got an EE for almost 30 yrs and a Masters in EE and SE as well. LOL. I think I'm over qualified to answer.
Rulives, sounds like you are well under way to figuring it out. and yes, it sounds like bad diode. Easy fix.
I'm sitting at Spring Cove right now with Mai Tail in hand. Hit Tiki bar last night. My old man may be coming this August. We are also planning to see him next spring.
Stink on poop! Lol. Good thing I built a filter for that!
