Honda generator vs inverter
I'm looking to operate about a1000 watts ac which equates to 83 amps dc. Will 4 105 amp hour batteries be sufficient? I'm figuring 4 hours at 80% I am looking to run my 7,000 btu on board ac unit as well as the tv. My guess is that the ac unit will only run part time once the boat is cooled off which might give me an extra hour or so on the inverter. The Honda generator is great but storing the unit as well as having enough gas to run the genny all night is my concern, not too mention the noise. Any and all advice is appreciated. Thanks in advance
duane
duane
I'd go with a generator. You can run it for 7 hrs on 1 gallon of fuel. Running ac off of battery is just not efficient and won't make it half as long. Then you have batteries that will need a long time charging. genny you just add fuel.
Tony, I agree with you. I will say, if used and wired correctly, the portables are really great! Also typically more reliable and runs more efficient too. I'll also add the Honda makes one of the best. I've seen a Honda integrated into the boat (water thru exhaust) and it was really great!
http://www.nextgenerationpower.com/marinegen.html
http://www.monaromarine.com/298 Photos/pages/Generator Storage.htm
i installed this door last year with the sole purpose of storing a honda genny. seriously thinking about removing the hot water tank since we don't use it. i am only working with a 250ec so space is more limited than a 270. guess it's time to start figuring out how to run the exhaust!
A few things to consider. Your current calculation assumes perfect AC to DC conversion. In reality the conversion efficiency is approx. 90%. So you would have to supply closer to 93 Amps DC. The amp hour (Ah) rating on a battery is typically measured over a 20 hour period. Therefore, those batteries can supply 105 Ah when supplying 5.25 Amps. The Ah rating decreases as you discharge faster. Beware that some battery suppliers measure over a 100 hour period to inflate their Ah rating. Battery life is inversely proportional to the degree of discharge. Therefore, batteries discharged by more than 80% will survive significantly fewer cycles than batteries discharged to 50%.
Given that the AC need 660 watts when running I think that you would need a minimum of 6 105 Ah batteries to have any degree of success. Even then you would likely experience reduced battery life due to the degree of discharge. As long as the inverter can handle the AC starting load, I would be less concerned with the brief load on the batteries when calculating capacity.
http://t.harborfreight.com/engines-generators/gas-engine-generators/2500-peak2200-running-watts-47-hp-125cc-portable-inverter-generator-61169.html
