Buffing and polishing
Member Posts: 3,035 ✭✭✭✭
2003 FV 310. I am sure to get many opinions on this but I am seeking feedback on experiences of machine buffing compound and waxing/polishing goop brands etc that you have had success with or I should drop in the deep end. The surface is pretty good with areas of dullness but I want to be sure to use the right stuff to bring her up to the best again.
Thanks, Ian
Thanks, Ian
Wet sanded by hand with 2000 grit (not as hard as it sounds), machine compound/wool bonnet, machine polish/foam pad, then applied a uv/boat wax. ARDEX is the mfg. their stuff is awesome! Happy with the outcome but the real test with a colored hull is how long it will last. This is my first go around and i have a black hull. ...Rumor is its a losing battle,lol. Good luck
http://forums.sbo.sailboatowners.com/showthread.php?t=117266
06 Rinker 270
Ditto on Buff Magic with a Pro Polish follow up for light to moderate oxidation. -Paul
